Noticias
Volumio 1.5: el mejor reproductor audiófilo de la historia
And yes, it still sounds great!
Going straight to the point: Volumio has finally reached 1.5 version. And this new release is something you’ll love, let’s see why:
SPOTIFY SUPPORT
volumio-spotify
That was long awaited. Just insert your Spotify credentials into Settings page (a premium account is required) and there will be no music you can’t listen to. You have full Spotify search and all your playlists listed on the Spotify section of the Browse tab. This amazing feature was made possible thanks to the contribution of Volumio community member ning-you (huge thanks for this) and to an awesome daemon by Schnouki called SPOP. Needless to say, even Spotify’s sound quality sounds impressive on Volumio.
FULLY REVISITED LIBRARY TAB
volumio-library
Volumio community member Jotak did it again. He reworked its brilliant Library Tab ensuring it will work better and reducing significantly the load it applies to the system, mostly thanks to this brilliant feature. It’s really a feature I cannot live without. It comes disabled by default, to enable it just go to settings and tick the library tab, you can also choose to see it as a tab or as an entry in the browse section. Jotak made also lots of other improvements to Volumio, like the following.
UPDATE SYSTEM
volumio-updates
Yes, the next Volumio updates (at least not critical ones) will not require a complete re-flash of the system. Jotak developed this system which wil allow you to receive new updates with just a push of a button. Go to settings and check updates, if new updates are found you’ll be prompted to apply or ignore them. Does this sound great just to me? Of course there could be something we didn’t think on, and we need to test this capability. So please let us know what happens when new updates will be released.
UPDATE: To benefit from Updates system you must create a new SD Card with 1.5 release, from now on you’ll be able to update without reflashing!
SOCIAL SHARING
volumio-social
The tunes you listen may sometimes be memorable. Let your friend know about it. Now Volumio features Twitter, Facebook and Google+ sharing mechanism. The last 2 are still a work in progress, since we need a long and necessary verification, but expect them to land soon (via updates!)
REWORKED NETWORKING
volumio-network
Now Volumio can connect to every network without issues, the whole network managemet now works just flawlessly. And let’s you understand the quality of your connection.
UPNP with OHMEDIA SUPPORT
As you already know, Volumio uses the excellent UPNP\DLNA mpd plugin upmpdcli. This awesome piece of code has been recently updated to include OpenHomeOhMedia Support. Quoting from Upmpdcli:
OpenHome is probably supposed to be some kind of industry alliance, but, as far as I know it is exactly composed of Linn Devices, a British supplier of high end audio equipment.
OpenHome has published ohMedia, a set of standards for network audio, which have been implemented in a number of hardware and software products beyond those from Linn.
ohMedia is based on the UPnP base protocols, but it uses different services. The most important difference from the user point of view is that ohMedia has a PlayListservice which manages the play queue much in the same way that MPD does.
Some of the best UPnP control point software packages (e.g. Bubble UPnP, PlugPlayer) include support for both bare UPnP and ohMedia. In cases where a device supports both interfaces, they will default to ohMedia. Using several ohMedia control points on the same device is not a problem, but mixing UPnP and ohMedia control points is sure to end in confusion because of the very different play queue management.
What does this mean? You will be able to control your Playlists and PlayQueues with excellent Upnp client like BubbleUPNP and JamCast!
DSD Direct Playback
Now Volumio can play DSD Audio in direct mode: this allows to play them in bit perfect mode, if your DAC supports them. If not you can choose to play them in DoP mode (DSD Over PCM)now it’s up to you to decide wether DSD is the future of Digital Audio Playback.
Raspberry PI B+ I2S DACs Compatibility
Volumio is now fully compatible with Raspberry PI B+, and all the most famous i2s DACs available. Just connect them, go to settings and enable yours. Harware Volume Mixer works as well.
LOT OF REFINEMENTS AND NEW CAPABILITIES
This release features a big amount of improvements and refinements, both under the hood and in term of User interface. Just to quote some: you’ll be able to add your WebRadios from the WebUi, disable the Startup Sound (another new feature), change the Player Name and more.
This release was prepared in a long period of time, trying to address all the precious feedbacks and suggestions and involving the community actively. I want to publicly say thank you to everyone in our great community: what Volumio is now is thank to you, the passion, the brilliant insights and the discoveries you’ve put into this.
As usual you can download it from download page and leave your feedbacks and partecipate into Volumio development on this thread
Today, you’ll find just Raspberry Pi release, on the following days I’ll update ALL the other platforms. Stay tuned!
And this, is the full changelog:
-Full Spotify Integration
-Reworked Library TAB
-Update System Introduced
-OhMedia UPNP Support
-AirPlay issues fixed
-Selectable Player Name
-System services selector
-WebRadios can be added from WebUi
-Clear Whole queue from WebUi
-Social Sharing
-Direct DSD Playback
-Full I2S B+ DACs compatibility
-Better i2s DACs management
-Networking Page Reworked
-Song title in Browser Tab
-Startup Sound
-Shell shock bug fixed
-MPD 19.1
autor-avatar
Sobre Michelangelo Guarise
Apasionado. Hereje. Profundamente enamorado de la tecnología y la música. Vivo en Florencia, Italia, donde enseño Diseño de Interacción y Marketing. Soy el fundador y CEO de Volumio, y me encanta cada segundo de esta gran aventura. Mi equipo de audio es una extraña mezcla de amplificadores de válvulas y digitales, todos construidos por mí mismo en algunas frías noches de insomnio invernal. Y no puedo bajar el volumen.
Entradas relacionadas
36 thoughts on “Volumio 1.5: the best Audiophile Player ever”
  1. Юрий says:
    and the point of using the network of the program is lost, because after a bad mount, the program re-installation of the new
  2. Юрий says:
    Не сильно радуйтесь шаре и тп, софт безбожно глючный а поддержки вообще никакой
    1. uncle_wired says:
      ось не пизди
  3. Reiner Puerling says:
    Where Tod buy Durio Sound Pro card for Rpi?
  4. mahmood says:
    I just opened this ticket on Spotify forums suggesting that they have to support the efforts of the Volumio team: https://community.spotify.com/t5/Spotify-Ideas/Volumio-Sponsorship/idi-p/994067. Vote for it if you like…
  5. mahmood says:
    For the first time I can’t hear the difference between streaming music (from Spotify) and the lossless audio files in my library. My sound system is suddenly worth 1000$ more… Thanks man!
  6. Kunter Kutluay says:
    Just installed 1.5 on CuBox… A big thank you!!! Such an improvement in sound and functionality.
  7. Mikhail Seliverstov says:
    Still waiting for CT version 1.5!
  8. NORI says:
    Great Release! Still waiting for CT!
  9. Lincoln Stein says:
    Still waiting for 1.5 Cubox-i version. Are there instructions for installing from github source?
  10. Captain Yogen says:
    So no Spotify for free users?
    Would anyone be kind enough to let me use their premium account just to test it? (I’m presenting volumio on a Rpi as a school homework, showing Spotify connection would be great)
  11. Kunter Kutluay says:
    Waiting for the Cubox-i version of 1.5.
  12. Lincoln Stein says:
    Waiting for Cubox-I version of 1.5. What is ETA?
  13. barreatouffe says:
    Perfect ! THX 😉
  14. Benny Jo says:
    Waiting 1.5 for Cubietruck.. tks.
  15. CHEN says:
    Waiting for Cubietruck!
  16. hjianhao says:
    When I upgraded from 1.4 to 1.5 for my raspberry, It could not play music higher than 16bit / 44.1khz. It can play well when I used version 1.4.
    1. hjianhao says:
      I use raspberry(512m) + hifiberry Digi
  17. Nigel says:
    When does Cubox-i receive version 1.5? Thanks, Nigel
  18. Atreyu says:
    Great release, I encounter a few small bumps and will log the on Github when applicable.
    Is Spotify ‘connect’ (https://www.spotify.com/nl/connect/ : control of Volumio playlist from Spotify desktop/Android/IOS client) in the making?
  19. blueroom says:
    I can’t wait for the Cubox-i release, I’ve been waiting for this for some time, regularly checking back. 🙂 Thanks again for all your hard work, its VERY much appreciated!
  20. starlight says:
    I have a problem with the icons on firefox 33.0.2
    http://hpics.li/f625c7f
    ps : with ie or chrome no problem
    1. Atreyu says:
      Same issue here, fixed by clearing the cache and refreshing the page.
      It seems to have something to do with font-awasome.min.css not loading properly.
  21. Alexis J. says:
    Great job! Soon avalaible for Udoo ? 🙂
  22. Marcello says:
    Great I just started exploring 1.41 ( RasPi B+) and can not comment on an old version.
    So let me upgrade tonight.
  23. Ikem Krueger says:
    I visited your homepage and clicked on the “Discover” button. I expected to see some screenshots, but I only saw text.
    Please put some screenshots on your homepage, so that the people get an idea how your product look like.
    And didn’t need to search for screenshots, like I did.
  24. Reid Peryam says:
    Wow you guys impress the hell out of me.
  25. bdouble says:
    Congrats to the team, can’t wait to try Volumio on my Cubox i4!
  26. Valery says:
    I try to use Rasp with ES9018 DAC (diyinhk) in I2S connection – it’s don’t work, like in previos version of Volumio. I can’t see my HDD, connecting to Rasp trough USB, in networks drives, like in previos version of Volumio. System freez twice in one hour, like in previous version of Volumio. But now we have a useless Spotify – great! 🙁 (sorry for my english)
  27. rodskin says:
    Awesome!!
    I have issues with my volumio so i will update to this version and check what is going wrong.
    Is there a google music / soundcloud support on its way ? (for those who don’t use spotify)
  28. Rene Arts says:
    Fantastic! Lots of very usefull improvements again! Great job 🙂 I guess it’s time to donate again!
Leave a Reply
Your email address will not be published. Required fields are marked *
