Noticias
Volumio para Raspberry PI 2
Everyone was thrilled when the new Raspberry Pi 2 was announced earlier this week
And so did I! And you should be really happy that Volumio Audiophile Music Player is now available for Raspberry Pi 2!
Let’s take a moment to review what the benefits are with this new board iteration:
  • Quad Core ARM v7 CPU @ 900MHz (Foundation claims it to be 6x more powerful)
  • 1GB of RAM instead of 512 MB
  • Full compatibility with Accessories and Software of V1.
The new Raspberry Pi 2
What they basically did was replace the BCM2825 SoC with a newer and more powerful BCM2836, and adding a 1GB elpida DDR2 RAM module on the bottom of the board. The remaining parts of the board remain unchanged.
You can see an interesting performance comparison here.
For those of you wondering if the new Raspberry Pi 2 will suffer from the same USB issues: yes, the Ethernet is still over USB (like every single board computer out there) so we’ll need to test the new drivers behaviour extensively to see if the notorius #1 bug on PI has been solved.
Now, let’s see what you can get using Volumio and Raspberry Pi 2 as a music player:
  • 35 dollar Hardware, the most inexpensive one
  • Way more power than Volumio needs
  • Full compatibility with I2s DACs (Hifiberry, IQ-Audio and others) up to 24\192 playback
  • Extra RAM for RAMPlay function
I’ll cover a bit more extensively the hardware capabilities of the Raspberry PI 2 in a future post
And here is what you get with Volumio 1.55:
  • Compatible with Raspberry Pi, Rasbperry Pi B+ and Raspberry PI 2
  • I2s DAC compatibility with Raspberry PI 2 (Hifiberry Dac Plus, IqAudio Dac Plus and others)
  • Better Spotify handling: new Spop daemon version and search by Name or Artist
  • USB DAC hotplugging is now supported
  • USB Storage can be used on the fly, and you’re not required to reboot any more
As usual, you can download the new version at the DOWNLOAD PAGE and leave your comments and feedbacks on the Specific Forum Thread
And while downloading, take a look at the great Android Companion Apps for Volumio!
¡Que aproveche!
Entradas relacionadas
4 thoughts on “Volumio for Raspberry PI 2”
  1. skanet says:
    Is it compatible with RPi3 B ?
  2. gio says:
    Congratulations!!!
    good work!
  3. Jakob Riedel says:
    Just a shower thought: To solve #1 bug, would it be possible to run network communication through an expansion board?
    This would circumvent the USB ethernet, right?
  4. taurui says:
    I just borrowed a Raspberry 2 from a friend just to check if the performance on HD files is better than with the “old” PI.
    Up until now… looking much better. No clicks, stutters or whatever you might call them.
    Can you verify this?
Leave a Reply
Your email address will not be published. Required fields are marked *
