Made with SABRE DACs connected in I2S to the digital input section, that can satisfy any enthusiast entering the world of streamers.
PRIMO lets you stream from your favorite music services such as Spotify, Tidal and Qobuz.
One-on-one support to help with everything from set-up to troubleshooting. Always available for you!
"Audio lovers, prick up your ears, because the Primo is surprisingly good."
Martijn ten Napel
"The Volumio Primo is characterized by particularly compact dimensions so that it can be placed in any environment, is easy to install, ensures access to your own content as well as important online services"
Michael Holzinger
A truly complete product, for those who already have an audio system and want to complete it with a high-level DAC-Streamer.
Volumio Primo was made with the top of the SABRE DACs -the ESS 9038Q2M– in differential configuration connected in I2S to the digital input section, that can bring any enthusiast to the world of streamers without compromising.
EASY SETUP
Getting started just takes a couple of minutes with the Volumio official iOS and Android apps
All Volumio products are proudly designed and assembled in Florence Italy
All Volumio products are Roon Ready certified by Roon Labs. allowing seamless integration with Roon
On board, the Primo is the latest version of Volumio – Volumio AI- that incorporates Supersearch an AI-powered search function that is meant to optimize your music discovery.
Volumio OS comes with a Multi-room capability that creates an integrated environment with other Volumio stations in your home.
Audio playback
Bit-Perfect up to 192 kHz 24 bit.
Video output
HDMI 2.1/HDCP 2.2 up to 4K 60fps
Analog Audio Output
RCA/XLR: 2V RMS
USB
1x USB3.0, 1x USB 2.0
LAN
Gigabit 10/100/1000M
Wireless
Wi-Fi 802.11a/b/g/n/ac, 2X2 MIMO with RSDB
Bluetooth
5.0
Supported Formats
DSD, WAV, FLAC, Alac, Aac, Vorbis, Cue, Mp3 and others
UPNP DLNA
Renderer with Open Home support
Supported Services
Airplay via Shairport Sync, Spotify & Spotify Connect, TIDAL & TIDAL Connect, QOBUZ
Available Plugins
Youtube, Squeezelite, Radio Paradise, Podcasts, Pandora, Fusion DSP, Roon Bridge, Soundcloud, Mixcloud
CPU
Amlogic S905D3, Quad Core 1.9 GHz
RAM
2 GB DDR4
Internal Storage
16 GB EMMCz
Power Supply
5V, 3A
Designer
Design Narratives Ltd.
Weight
2.25 kg
Dimensions
33.5 × 20.5 × 11 cm
Downlod Volumio Primo User Manual Below:
Reviews
