- Clock
- Rivo Ultra: Femto-clock, 54 fs RMS phase noise, for the integrated outputs; TCXO for the USB hub
- Rivo Plus: MEMS clocks for the USB hub and the output ASIC
- Power supply
- Rivo Ultra: Internal dual linear supply, 115–230 V AC
- Rivo Plus: External 5 V DC / 3 A
- I2S over HDMI output
- Rivo Ultra: Up to PCM 768 kHz / 32-bit and DSD1024
- Rivo Plus: Up to PCM 768 kHz / 32-bit and DSD512
- S/PDIF coaxial output
- Rivo Ultra: RCA and BNC
- Rivo Plus: RCA
- S/PDIF optical output
- Rivo Ultra: 2 × TOSLINK, up to PCM 192 kHz / 24-bit and DSD64 via DoP
- Rivo Plus: —Not available
- Display and remote
- Rivo Ultra: 12″ touchscreen, a knob with its own display, Remoto included
- Storage for your music
- Rivo Ultra: NVMe slot for a PCIe SSD up to 16 TB, plus USB drives
- Rivo Plus: USB drives
- Processor
- Rivo Ultra: ARM Cortex-A76, quad-core, 2.4 GHz
- Rivo Plus: ARM Cortex-A55, quad-core, 1.9 GHz
- Size and weight
- Rivo Ultra: 44 × 34 × 9 cm, 6 kg
- Rivo Plus: 27 × 15 × 5.2 cm, 1.12 kg
- Finishes
- Rivo Ultra: Full aluminum, or aluminum and leather
- Rivo Plus: Classic, or the Special Edition in brown leather
- On both
- USB DAC output up to PCM 1536 kHz / 32-bit and DSD1024, with multiroom off. AES/EBU and S/PDIF coaxial up to PCM 192 kHz / 24-bit and DSD64 via DoP. 2 GB DDR4 and 16 GB eMMC. Gigabit Ethernet, dual-band Wi-Fi and Bluetooth 5.0. HDMI up to 4K / 60 fps. 12 V trigger. Premium features built in.
