Shop
Back to News
News
Audio OEM: Build a Streamer People Want
A beautiful component can earn attention at a hi-fi show. What earns a permanent place in a listening room is the experience after the customer gets home. For an audio OEM, that experience is increasingly defined by software: how quickly music starts, whether a local library feels alive, how naturally streaming services fit together, and whether the product remains reliable years after purchase.
Connected audio is no longer an optional add-on to a traditional hardware range. It is where listeners choose music, manage their systems, discover artists, and form an opinion about a brand every day. Building that experience well requires more than adding a network module to an existing amplifier, DAC, or speaker.
The connected product is the real product
A network streamer sits at the meeting point of several expectations that used to be separate. A customer may want to play a carefully tagged NAS library one evening, use Qobuz the next, send music from a phone during a dinner party, and control volume across an integrated system without thinking about protocols or source switching.
From the listener’s perspective, these are simple requests. For a manufacturer, they involve streaming integrations, library indexing, playback architecture, control apps, hardware drivers, account authentication, network behavior, and ongoing support. A product can sound extraordinary and still create frustration if its interface is slow, its setup process is brittle, or software maintenance is treated as a one-time launch task.
That is why the strongest connected products begin with a clear listening promise. Is the goal to make a reference DAC easier to live with? To bring a brand’s amplifier heritage into multiroom listening? To give a compact all-in-one system the confidence of a serious source component? The technical choices should serve that promise, not obscure it.
What an audio OEM partnership should provide
An audio OEM relationship is often described as a shortcut to market. Speed matters, but it is not the full value. The right partner gives a brand a mature foundation while leaving room for the product to feel recognizably its own.
That foundation should include dependable playback from local and networked sources, major streaming-service support, a coherent control experience, and an update path that can evolve with changing services and customer expectations. It should also account for the less visible work: certification requirements, security updates, diagnostic tools, provisioning, and the support questions that arrive after thousands of units are in homes.
For a hi-fi manufacturer, this allows internal engineering teams to concentrate on the areas where they create genuine distinction. That may be analog output design, clocking, power supply architecture, industrial design, speaker integration, or a carefully voiced amplifier stage. It is a better use of expertise than repeatedly rebuilding the basic plumbing of digital music playback.
There is a trade-off. A fully bespoke platform can provide maximum control, but it brings a long development cycle and a permanent software obligation. A ready-made platform can launch sooner and benefit from proven behavior, but only if it is flexible enough to support the brand’s hardware, visual language, and intended customer journey. The practical answer is rarely all-or-nothing. Most successful projects pair a stable music platform with purposeful customization.
Differentiation is not just a new control app
It is tempting to define differentiation through appearance alone: a new app skin, a front-panel display, or a distinctive enclosure. These choices matter, particularly in premium audio, where an object should feel at home beside the rest of a system. But the deeper differentiators are often felt rather than announced.
A listener notices whether browsing an album collection is immediate. They notice whether the product wakes reliably, remembers its state, and handles high-resolution playback without ceremony. They notice whether a search result makes sense when local albums and streaming catalog results appear together. Those details create confidence, and confidence gives customers a reason to stay with a product instead of replacing it when their habits change.
A strong platform should therefore be customizable at the level that matters. Manufacturers may need tailored input behavior, unique display flows, product-specific settings, branded onboarding, or integration with their own control ecosystem. The objective is not to make proven software unrecognizable. It is to make the overall experience feel intentional.
Start with the listening journey, then specify the hardware
Hardware requirements become clearer when they are built around real use cases. Consider the difference between a dedicated transport feeding an external DAC and an all-in-one amplifier with streaming built in. Both may share network and software foundations, yet their priorities are different.
The transport owner may expect detailed control over digital outputs, playback formats, and DAC compatibility. The all-in-one owner may value clear setup, volume behavior, input selection, and an interface the entire household can use. A portable or compact product may need fast Wi-Fi provisioning and minimal physical controls. A flagship component may call for a high-resolution display, elaborate metadata presentation, and deep system integration.
These decisions affect processing power, memory, storage, connectivity, display hardware, thermal design, and the relationship between the playback engine and audio board. They also affect the test plan. A product intended for an enthusiast with a wired network and a large library should still be evaluated in the imperfect conditions found in real homes: crowded Wi-Fi, mesh routers, changing passwords, mixed file formats, and family members who expect music to work on the first attempt.
This is where experienced integration pays for itself. The challenge is not merely proving that a prototype plays music in a lab. It is ensuring that the finished product behaves gracefully across a wide range of systems and routines.
Updates are part of the ownership experience
Digital music changes after a product ships. Streaming services adjust their requirements. Mobile operating systems evolve. New playback capabilities emerge. Security expectations rise. A connected component that cannot be maintained gradually becomes less valuable, regardless of the quality of its audio circuitry.
Manufacturers should treat the update strategy as part of the product specification from day one. That means deciding how updates are delivered, how releases are tested, what happens if an installation is interrupted, and how customers learn about useful new features without being overwhelmed by technical detail.
It also means setting honest expectations. Frequent updates are not always a sign of quality if they introduce instability. Conversely, silence is not reassuring when services and devices around the product continue to change. The ideal cadence is measured: regular maintenance, careful validation, and meaningful improvements that respect a customer’s time and listening habits.
A proven platform can reduce this burden because its update mechanisms, device management, and playback behavior have already met a broad community of users. Volumio brings that perspective from an ecosystem shaped by both dedicated hi-fi components and hands-on music lovers building their own players.
The questions worth asking before development begins
Before selecting a software and integration partner, a manufacturer should look beyond the feature checklist. Features can appear equivalent on a presentation slide while the real-world experience differs substantially.
Ask how local libraries are indexed and presented, not only which file formats are supported. Ask how service integrations are maintained when APIs change. Ask whether the platform can accommodate the intended hardware architecture and user interface. Ask how issues are diagnosed after deployment, and who owns each layer of support.
It is also worth asking which parts of the experience can be shaped without creating an expensive fork that becomes difficult to maintain. A good partner will be direct about boundaries. Some standardized behaviors protect reliability and make future updates practical. Other areas should be open to design because they are central to the manufacturer’s identity.
Finally, evaluate the partnership as a long-term collaboration rather than a software purchase. Connected products have a lifecycle. The teams involved need a shared way to prioritize improvements, investigate field issues, and make thoughtful decisions when a new opportunity or constraint appears.
Build for the moment music becomes personal
The most compelling connected components do not ask customers to think about software. They let a favorite album begin with the right sense of occasion, whether it comes from a decades-old local collection or a newly discovered release. The interface recedes, the system feels coherent, and the brand earns trust through every ordinary listening session.
That is the standard worth designing for: not simply a streamer that can connect, but a music experience that gives people another reason to sit down, choose an album, and listen.
Back to News
