Shop
Back to News
News
DSD versus PCM for Better Digital Listening
A favorite album can arrive in several digital forms, and the labels can feel more consequential than they are. In the discussion of DSD versus PCM, there is no universally superior format waiting to transform every system. There are different technical approaches, different playback requirements, and, most importantly, different recordings and masterings behind the files.
The useful question is not simply, “Which has more numbers on the spec sheet?” It is: which version of this music was prepared with care, and can your player, DAC, and system reproduce it as intended? Once those pieces are in place, both PCM and DSD can deliver deeply involving listening.
DSD versus PCM: two ways to represent music
PCM, or Pulse Code Modulation, represents an audio waveform by measuring its level at regular intervals. Each measurement is assigned a numerical value. The two specifications most listeners encounter are sample rate and bit depth: CD-quality PCM is 16-bit/44.1 kHz, while high-resolution releases may be 24-bit/96 kHz, 24-bit/192 kHz, or higher.
This is the foundation of digital audio as most people know it. PCM is used for CD, downloads, streaming, studio recording, editing, and mixing. It is mature, widely compatible, and exceptionally capable. A well-mastered 16-bit/44.1 kHz file can sound superb, while higher sample rates and bit depths can offer practical advantages during recording and production.
DSD, short for Direct Stream Digital, takes a very different route. Rather than storing multi-bit samples at a comparatively lower rate, it uses a one-bit stream sampled at an extremely high frequency. Standard DSD, often called DSD64, runs at 2.8224 MHz. DSD128 doubles that rate, and DSD256 doubles it again.
Because a one-bit signal has limited instantaneous resolution, DSD uses noise shaping. It moves much of its quantization noise out of the audible band and into ultrasonic frequencies. A DSD-capable DAC then uses filtering to remove that ultrasonic noise before the signal reaches your amplifier.
Neither approach is a simple shorthand for sound quality. PCM and DSD use different engineering compromises to preserve the musical signal. Their specifications cannot be compared line for line, so DSD64 is not directly equivalent to a particular PCM sample rate just because both are described as high resolution.
Why the format alone does not decide the sound
The mastering is usually the decisive factor. If a DSD download was made from an excellent analog tape transfer and a PCM version came from a compressed, heavily limited remaster, the DSD release may sound more open, relaxed, or natural. But that does not prove DSD is inherently better. It may simply be the better master.
The reverse happens often enough to matter. Many DSD releases originate from a PCM recording, mixing, or mastering chain. That is not automatically a problem. Modern PCM production can be transparent and highly precise. Still, converting a PCM master to DSD at the final stage does not restore information that was not present in the original recording.
For this reason, compare editions rather than formats in the abstract. Look for the release date, mastering engineer, recording provenance, and source notes when they are available. A carefully transferred DSD64 album can be more satisfying than a poorly handled DSD256 release. A thoughtful 24-bit/96 kHz PCM master can be every bit as compelling as an outstanding DSD file.
Your DAC also has a voice in the result. Some DACs process DSD natively, while others convert it internally to PCM. Some offer a direct DSD path that minimizes processing, and some use filter choices that subtly change the presentation. PCM playback has its own variables, including reconstruction filters, oversampling, and clocking. These design choices can be more audible than the format label on the file.
The practical case for PCM
PCM is the format of convenience without being a compromise in musical potential. It is supported by nearly every playback device, music service, recording application, and DAC. If your library combines CD rips, downloads, live recordings, and streaming favorites, PCM provides the broadest path to playing everything without friction.
It is also the natural format for music production. Editing, equalization, level adjustment, room correction, and digital volume control are generally performed in PCM. That flexibility matters if you use DSP in your system, whether for headphone equalization, subwoofer integration, or room correction.
PCM files can also be more storage-efficient than equivalent DSD releases. A 24-bit/96 kHz FLAC file preserves PCM audio without loss while taking less space than many DSD files. For a large personal library, that difference can become meaningful, especially when backups are part of the plan.
None of this means PCM has to sound clinical or merely practical. The best PCM playback is spacious, tonally complete, and remarkably faithful to the character of a recording. Its ubiquity comes from reliability and versatility, not from a lack of refinement.
When DSD makes sense
DSD is especially appealing when you have access to recordings created or transferred thoughtfully in DSD and a DAC designed to handle it well. Classical, jazz, acoustic, and archival recordings are common places to encounter carefully produced DSD releases, partly because subtle ambience, instrumental tone, and dynamic gradation are priorities for listeners and labels alike.
Some listeners describe excellent DSD playback as fluid, continuous, or unusually relaxed. Those impressions are valid personal responses, but they should not be treated as universal properties. Another listener may prefer the focus, immediacy, or tonal balance of a different PCM master through the same system.
DSD also asks a little more from the playback chain. Native DSD support varies by operating system, network player, USB driver, and DAC. Some systems send DSD as DoP, or DSD over PCM, which packages the DSD data for transport without converting the audio itself to PCM. Other systems can send native DSD. Both can work very well when properly implemented, but compatibility should be confirmed rather than assumed.
Higher-rate DSD files demand more from storage and network bandwidth, too. That is rarely an obstacle on a well-configured home network, yet it is worth considering if you maintain a large library or stream files to multiple rooms.
Choose the playback path before chasing formats
A capable music player should make format handling feel secondary to the listening experience. It should organize your library, identify the file type, send the signal appropriately to a compatible DAC, and keep your focus on the album rather than the file extension.
With a platform such as Volumio, the important setup question is whether your connected DAC supports DSD and which transport method it expects. In settings, avoid converting formats unnecessarily unless your DAC requires it or you are intentionally using DSP. If native DSD playback is available, test it with a familiar recording. If PCM conversion is required, do not assume you are losing the essence of the music before you listen.
There are a few practical checks worth making before buying a DSD-heavy library. Confirm the maximum DSD rate your DAC accepts. Check whether it supports native DSD, DoP, or both. Make sure your chosen output connection supports the rate you intend to play, since USB, network playback, and some digital connections have different capabilities. Finally, consider whether you use DSP, because it may mean DSD is converted to PCM for processing.
That last point is not a failure of the system. DSP can produce far larger audible improvements than changing file formats, particularly in a room with bass problems or poorly integrated speakers. A well-executed room correction profile and a great PCM master may bring you closer to the performance you want than a format change ever could.
A better way to build a high-resolution library
Treat DSD as a valuable option, not a collecting contest. Buy or keep DSD releases when they offer a preferred master, a recording you love, or a direct transfer with convincing provenance. Choose PCM when it is the best available edition, when you need broad compatibility, or when your system uses digital processing.
For an honest comparison, level-match as closely as possible and listen to complete passages, not just a few dramatic seconds. Use music whose phrasing, room ambience, vocals, and instrumental textures you know well. If two versions are from different masters, recognize that you are comparing production decisions as much as formats.
The file that earns a place in your library is the one that makes you stay for the next track. Let your ears, your system, and the quality of the mastering lead the decision.
Back to News
