Introducing Rivo Ultra, our flagship streamer transport
Today we introduce Rivo Ultra, our new flagship streamer, above Rivo Plus. Engineered from scratch with audio-grade components, it feeds ultra low-jitter digital audio to your DAC.
Rivo Ultra is a streamer transport: it plays your music and sends it to the DAC you already love, bit-perfect, from a version of Volumio OS tuned for it.
Five ways to your DAC
Rivo Ultra has seven digital outputs: USB, I2S/DSD over HDMI, AES/EBU, two S/PDIF coaxial (one on a BNC connector, one on RCA) and two S/PDIF optical. The USB output goes up to PCM 1536 kHz / 32-bit, I2S/DSD over HDMI up to PCM 768 kHz / 32-bit. A 12 V trigger switches your other components on and off.
Inside, a dual linear power supply feeds it. An NVMe slot takes an SSD of up to 16 TB for your music library.
See what you hear
The 12″ touchscreen on the front shows what is playing and lets you control everything, and the knob has its own display for the essentials at a glance. Remoto, the Volumio remote, comes in the box. You can also use the Volumio app on iOS and Android, or connect the HDMI video output to your TV, up to 4K.
Volumio Premium built in
The Premium features belong to this Rivo Ultra, with no subscription. Stream with your TIDAL, Qobuz or Spotify account, plus their Connect features and AirPlay, play local or network drives, or internet radio. Rivo Ultra is Roon Ready and joins the other Volumio players in your home for multiroom.
Two finishes, made in Florence
Rivo Ultra comes in full aluminum, or in aluminum with a stitched black leather top. It is designed in Florence, Italy, where every unit is assembled and tested by hand.
DSD versus PCM for Better Digital Listening
DSD versus PCM can both sound exceptional. Learn how their encoding, playback requirements, and mastering choices shape what you hear at home, clearly.
Hi Fi Streamer Buying Guide for Better Sound
Our hi fi streamer buying guide explains sound quality, DACs, connections, control, and upgrades so your digital music feels at home in your system daily.
Raspberry Pi for Better Home Music Streaming
Raspberry Pi can become a focused, great-sounding music streamer. Learn what matters most, from setup and storage to clean audio output at home daily.
